What model farmall is this
grizzthebear
01-02-2008 11:08:58
hello everybody I just aquaried a farmall B? and am trying to get a good handle on the model. I was told it was a B. It has hydrolics and a wide adjustable front end. It was parked next to a super A and is somewhat larger.
The serial number on the set bracket is 272818 and theres a casting number behind the oil filter 251069R1 i think as it is hard to read there. it also has the fireing order above the distrubiter.
there is also a cast number on the transmision just under the battery box 351687R1
it also has a pto and a belt roller on the back with a lever to engage the pto.
Any help with IDing the model of this thing would be helpfull.
Harold H
01-02-2008 21:01:45
 Re: What model farmall is this in reply to grizzthebear, 01-02-2008 11:08:58
It looks like a Super A. Since it has an aftermarket seat, the serial plate is probably missing.
Harold H
Keith-OR
01-02-2008 14:18:00
 Picture in reply to grizzthebear, 01-02-2008 11:08:58
Lets see if I can still do this.
Sure looks like an Farmall A to me..
third party image
grizzthebear
01-02-2008 11:59:50
Heres a picture of the tractor, not a good shop, I'll try and get something better tomorrow
gots-2-go
01-02-2008 14:22:28
 Re: What model farmall is this in reply to grizzthebear, 01-02-2008 11:59:50
Going by the picture posted, and if it has hydraulics as you said it would appear to be a Super A.
banjo
01-02-2008 19:51:02
 Re: What model farmall is this in reply to gots-2-go, 01-02-2008 14:22:28
seeing that we cant see the whole tractor, did the A"s have the IH or Farmall grill ornament. My super A"s have the IH on the grill like the one in the picture.Just wondered what the A"s had.
old
01-02-2008 12:29:17
http://www.tractorshed.com/cgi-bin/gallery/ident_pic.cgi?pic=http;//www.tractorshed.com/gallery/identify/a13417.jpg&firstrec=1&lastrec=15&Parameter=&mode=All&what=identify
Heres your picture. Its an A. Well that didn't work
old
01-02-2008 12:28:38
Dave H (MI)
01-02-2008 11:35:26
It's not a B with the wide front, etc as Andrew mentioned. Your serial number should have a prefix such as "FAB" for a B or "FAA" for an A. The seat bracket might not be original so that tag is worthwhile only if the stamped serial number matches on the engine (above #1 plug, may be hard to read if dirty). A picture would help if you could post one. That's about all I can think to help. Interested to know what you find out.
grizzthebear
01-02-2008 11:41:16
 Re: What model farmall is this in reply to Dave H (MI), 01-02-2008 11:35:26
It does have a model of FAA on the tag.
Thanks
old
01-02-2008 12:08:32
 Re: What model farmall is this in reply to grizzthebear, 01-02-2008 11:41:16
The FAA tells you the story on it. The first 2 letters stand for Farmall and the 3rd letter is the model of the tractor which would be an A. The B only came out with a narrow/trike type front end but the A had the wide front
Hugh MacKay
01-02-2008 11:34:15
Grizz: Andrew covered most of definitely not a B ad he gave you all the right reasons. If it is offset, it's got to be a Super A, no other offset ever reached that high serial number. In fact, the only other post 1939 Farmalls ever to surpass the 250000 mark were the H and M. Basically take Andrew's advice, you only have 3 tractors to look at SA, H and M.
Andrew Z
01-02-2008 11:18:15
Its not a B, no B has hydrolics or a wide front and they are much wider than the A, SA etc. Sounds to me it is a Super A with maybe larger tires to make it look bigger. Look on the side of the page for "tractor photos" and see what matches up there.
Andrew
grizzthebear
01-02-2008 11:39:53
 Re: What model farmall is this in reply to Andrew Z, 01-02-2008 11:18:15
it has 14.9-24 tractor tires on it and they are reversed so it looks wide and tall, also the center lines of the tractor tilts down to the front, not sure if this is normal or point to aftermarket tires.
Thanks for your fast repley
glennster
01-02-2008 11:43:08
 Re: What model farmall is this in reply to grizzthebear, 01-02-2008 11:39:53
do you have any pictures of the tractor, if so, post em on here or you can e mail the pics to me and i can try and post em for you.
