Farmall 140 PTO question
Bruce Covey
01-02-2008 17:55:18
Am considering a 140 or a Super A for both a toy and some light garden prep and grading work. Am concerned that the offset PTO may be a problem with running a 48" offset tiller, post-hole digger, and/or bush hog. Is this something I need to be concerned with? Is it suitable with all modern PTO implements? FYI.. I would be using a 3pt hitch conversion kit as req'd.
Haas
01-03-2008 06:32:02
 Re: Farmall 140 PTO question in reply to Bruce Covey, 01-02-2008 17:55:18
The Super A and 140 are geared way too fast for a rototiller. First gears is over 2 mph and you need a creeper gear 1 mph or less to do any good with a rototiller.
mark
01-03-2008 10:01:21
 Re: Farmall 140 PTO question in reply to Haas, 01-03-2008 06:32:02
Hass,
speaking of a creeper gear....is there anyway to install such a critter? I'd love to have one in my SA. If it were possible..... I'd toss 4th gear and have a creeper and 1, 2 and 3.
Hugh MacKay
01-03-2008 12:35:25
 Re: look in help identify in reply to mark, 01-03-2008 10:01:21
Mark: I posted a photo in help identify.
Hugh MacKay
01-03-2008 12:25:48
 Re: Farmall 140 PTO question in reply to mark, 01-03-2008 10:01:21
Mark: I have a photo on file of what is supposedly a gear drive creeper gear for Farmalls SA, 100, 130 and 140. This device bolts to back of tractor in place PTO. Near as I can tell it gets power in from tractor PTO drive, has a repositioned PTO shaft, actually closer to center of tractor. Then through a bottom shaft diverts power back to the differential.
This photo was sent to me along with a text, giving a brief description. I accidently deleted that text at the time. I never been able to contact that individual since. He found me through YT. I guess he was not a regular. I've had this on file close to 4 years.
mark
01-03-2008 13:11:26
 Re: Farmall 140 PTO question in reply to Hugh MacKay, 01-03-2008 12:25:48
Hugh,
I'll go take a look...thanks for posting it.
I'd like to think a machine shop could cut a low-low gear and 4th gear could be taken out and the new one installed in it's place. Just figuring out how many teeth and diameter of the gear is all I could see, one would need to figure out. Yes, it would be a big job to install, but you'd only do it once.
Hugh MacKay
01-03-2008 13:37:24
 Re: Farmall 140 PTO question in reply to mark, 01-03-2008 13:11:26
Mark: One question, is this transmission case wide enough for a large enough driven gear to give you a gear slower than 1st?
I don't know much about the device in the photo I posted, however I suspect he has used the same reduction gears as used in the factory PTO, and instead of having the driven pto shaft directly below the driver, he sets it at 45 degrees, then drives the tractor from that using only lower shaft of transmission. In other words his creeper only has one speed. He may do this using a pinion to the ring gear coming in from rear. I have toyed with building a similar device, putting PTO shaft dead center on tractor, then having a clutch between pto and drive to wheels. This would give Live PTO in the creeper gear.
Now I've got the wheels turning upstairs, haven't I.
mark
01-03-2008 13:44:51
 Re: Farmall 140 PTO question in reply to Hugh MacKay, 01-03-2008 13:37:24
Hugh,
I've never had a SA tranny apart to see what the gear train looks like....I suppose a person could refer to a repair manual and get an idea....but putting your hands on the real McCoy would be the best.I have no idea if the engineers that designed the transmission case only allowed enough room for the gears they would use....or made it larger than necessary. Maybe somebody who is familiar with the transmission innards will chime in and offer an opinion.
Hugh MacKay
01-03-2008 14:43:01
 Re: Farmall 140 PTO question in reply to mark, 01-03-2008 13:44:51
Mark: I have had one apart, there is some clearence, but I don't think it would be enough to give one a large enough lower shaft gear to reduce enough slower than 1st.
Are you familiar with Hydra Creeper drive. Decent little device, however one could not use the PTO while using the Hydra Creeper. It was basically a hydraulic motor on the PTO shaft and driven by a remote valve on the tractor. It came with a heavy duty clutch release bearing, and one tied the clutch down during use.
I've toyed with the idea of a modified PTO, placing the output shaft close to center rear of tractor. Then use a hydraulic pump and motor to give motive power to wheels. I've looked at placing the motor at front driving bottom shaft of transmission. This would require modification of torque tube.
mark
01-03-2008 17:08:29
 Re: Farmall 140 PTO question in reply to Hugh MacKay, 01-03-2008 14:43:01
Hugh,
Makes me wonder about the newer IH 274 transmission. I THINK it is a 6 speed...3 hi/low range, but it may be 8.
I have heard all sorts of stories about the last offsets sold by IH (274), JD (900HC), and Kubota (L245H). Some say they are great, others curse them.
I had a Yanmar built JD 1050 and if that 900HC was made as well.....there can be no flies in that ointment! I think the 900 was essentially an offset 950. They have 8 speeds.....a very slow creeper and a 3 cylinder diesel that sips fuel and is extremely reliable. I rarely ever see one for sale though.
Haas
01-03-2008 12:16:30
There was a creeper option for the Cub. Don't know about the super A. Don't know exactly how the cub creeper worked, but I don't think it was conventional gearing. There was a trencher available for the Cub, and that was one use for the creeper. I've never actually seen one, only photos.
NawlensGator
01-02-2008 22:14:30
I've used a 6' bush hog on the back of a 140 for 25+ yrs and am still using the same pto takeoff shaft. I've changed the U-joints once.
Also recently started using a 3 Pt sickle mower (7') on one without problem.
banjo
01-02-2008 22:10:50
One problem you may have is no independent pto for tiller use. if the ground is hard you might have a tough time with the speed of the tractor.Also if you modify the 3 point to get the driveshaft inline ,will you be able to till your tracks out.
Hugh MacKay
01-03-2008 04:16:42
 Re: Farmall 140 PTO question in reply to banjo, 01-02-2008 22:10:50
Banjo: If he's using a 48" tiller, he is not going cover tracks anyhow. I suspect he's planning to work from center out, with tiller offset, keeping the opposite wheel on the untilled soil.
Personally I'm not a very big fan of tillers, just an expensive way to till the soil. I've been growing garden vegetables and flowers, some years up to 20 acres, for over 45 years, never owned a tiller yet. I used to plow quite a few gardens for folks. One didn't need to see the tiller to know he was using one, the soil was a lot like concrete. I had one guy ask me why nothing would grow in his garden. I told him why nothing would grow, by asking him how much vegetation grew up through his concrete patio and garage floor. I went there with 130, moldboard plow, disk and s-tine cultivator. Hardest plowing I ever did, lifetime. He had that soil pulverized as fine as concrete, and believe me, it was set up almost as hard. I plowed, disked and cultivated it until I had a foot of loose plantable soil. As I loaded up my equipment, there he was, out there with his cement maker, happy as if he was all there.
Hugh MacKay
01-02-2008 18:17:12
Bruce: It can be done, but you have to hand pick the equipment. The auger shouldn't be too much problem as the shaft will be long enough the angle wont be that sharp. The best option with the tiller is buy one with center shaft then modify the 3 point hitch mounting to an offset position creating a straight line drive from pto.
CityBoy-McCoy
01-02-2008 18:15:33
Bruce:
All I can tell you is I have been using my Super A (with a Worksaver 3-point hitch) and a 60" finish mower for 3 years with no apparent problems. It is the family lawn mower and gets used regularly 6 months out of the year. Hope this information helps. mike durhan
