UK 3 Point Hitches
MJ in the UK
01-03-2008 06:59:43
Here in the UK we have had the 3 point hitch since 1936 on the Ferguson Brown tractor and it started to become popular in 1946 with the introduction of the Ferguson T20. The ferguson 3 point was Cat1 and in 1947 Ford put Cat 2 on the Fordson E27N tractor also Nuffield put Cat 2 three point hitch on its Universall tractor introduced in 1948. So as you can see the UK was used to 3 point hitches when they started building the Farmall M at Doncaster in 1949. The 3 point hitch they built for the M in 1950 used the Lift-all belly pump and rams working a cross-shaft to the lift arms. A picture of the linkage can be seen on Mike Farmers excellent shot of a golden Super BMD from a few days ago. The top link was mounted on the tractor with a bracket bolted vertically to the rear of the top cover.It was a very strong lift and i worked one for many years. IH used this lift till 1954 when they fitted an engine driven pump and a rear mounted lift cylinder. MJ
Harold H
01-03-2008 07:32:33
 Re: UK 3 Point Hitches in reply to MJ in the UK, 01-03-2008 06:59:43
The one they started using in 1954 with the internal cylinder, like on the Farmall B-450's imported over here, is what they SHOULD have put on the Farmall 400, 450, and 560 in the USA at the same time. IMHO.
Harold H
Hugh MacKay
01-03-2008 13:52:14
 Re: UK 3 Point Hitches in reply to Harold H, 01-03-2008 07:32:33
Harold: Right on, even if they wanted to flog fast hitch, with that rockahaft they could have done it in style.
Then if IH in the US had added that B-450 type rigid drawbar at least on the over 30 hp tractors.
