Selve price
olefarmallm
01-03-2008 12:54:12
How much does a new selvego for? 4 1/8 in bore
Thanks
Janicholson
01-03-2008 15:02:22
 Re: 4.125 Sleeve for an M in reply to olefarmallm, 01-03-2008 12:54:12
A new sleeve with piston will be between 80 and 100$
There may be someone on here with a sleeve if that is all you need. If it is cracked, be sure to check the bore casting, as the reason it cracked may have taken the block with it. A new repair sleeve would need to be put in it, then bored to fit the standard dry sleeve. LA Sleeve company can get it to you rapidly, Look on the net. Good luck, JimN
