Farmall M Hood holes
Zach Bouchard
01-03-2008 15:36:21
third party image
I have a Farmall M hood. I have 3 holes and i am not sure if they are all original. I don"t know what hole number 1 is for. Hole nuymber 2 is a hood hold down bolt. The third is the grease fitting for the steering shaft. But what is number 1 for. The numbers are a little hard to read but it starts with 1 and goes down.
randy hall
01-04-2008 08:43:03
 Re: Farmall M Hood holes in reply to Zach Bouchard, 01-03-2008 15:36:21
like dave slater advises that hole is for greasing the u-joint. without looking in the parts book i don't know when they stopped useing the u-joint that had a zerk on the side. on '39 hoods there were only two holes. they didn't have the nice washer and wingnut hold down.
Andy Martin
01-03-2008 17:59:10
Looks like the photograph has been reversed. The opening for the throttle rod is on the right and teh zerk access hole is on the left, so it"s a gas hood.
gene bender
01-03-2008 18:54:25
 Re: Farmall M Hood holes in reply to Andy Martin, 01-03-2008 17:59:10
The pic is reversed and the extra large hole would be for the gas tank either for a MD or a dual fuel engine. The muffler and air cleaner are one one side and the hole across from the air cleaner would be for the gas tank for starting until engine is switched for diesel or distillate.
Zach Bouchard
01-03-2008 17:54:24
It is off an M gas. I was just wondering if any of them need to be welded up.
D Slater
01-03-2008 18:30:06
 Re: Farmall M Hood holes in reply to Zach Bouchard, 01-03-2008 17:54:24
Some came with the extra hole in the hood because the universal joint was greasable. I remember a round hole. Can't tell from picture if hole is original shape, but it probably came with a hole there. I did know about what year the hole was elimanated but drawling a blank on trying to remember now.
Steven f/AZ
01-03-2008 16:21:13
The tractor may have come with, or someone replaced the U-joint with a greasable u-joint on the steering shaft... that's my best guess.
D Slater
01-03-2008 16:10:47
Think the # 1 your referring to was for some original type steering shaft universal joint greasing.
Andrew Z
01-03-2008 16:03:30
you got it Dave its off a diesel M.
Andrew
Red Dave
01-03-2008 15:48:06
I'm not an "M" expert, but I think that hood looks like it goes on an MD. It looks like the exhaust comes out the right side of the engine, Like an M Diesel.
Allan In NE
01-03-2008 15:41:36
This one is a '52.
Allan
third party image
georgeky
01-03-2008 17:19:12
 Re: Farmall M Hood holes in reply to Allan In NE, 01-03-2008 15:41:36
They sure look good looking down the hood of them.
Joe of J L Tractor
01-03-2008 16:23:49
What a clean garage or storage. Is the floor epoxied? Why does it look like mine and wet?
Allan In NE
01-03-2008 16:32:06
 Re: Farmall M Hood holes in reply to Joe of J L Tractor, 01-03-2008 16:23:49
Not mine,
Belongs to the fella up in South Dakota that I just bought the tractor from.
Allan
SD FARMALL
01-03-2008 17:44:35
 Re: Farmall M Hood holes in reply to Allan In NE, 01-03-2008 16:32:06
What part of NE ya from?
