Creeper Gear Offset Farmalls
Hugh MacKay
01-04-2008 03:01:42
Hendirk and Dale: You have some questions about this gear box. I actually know very little about it. The photo was e mailed to me, around 4 years ago. It had a very brief description stating that it gave 540 pto at rated engine speed, as well as a creeper gear, about 1/2 the speed of 1st gear. It came to me at a time I was away thus was in my mail box for a spell. I filed the photo and accidently deleted his e mail, and have never been able to contact him since. He found me initially via YT discussion as his first communication came to me via YT, stating he had photos for me. I have reason to believe this may have come from Centeral or South America, but not certain.
Dale, I believe this unit may use the same reduction gears from top shaft to the current pto as the distance looks about the same as if factory. The only way I can see a creeper speed coming from this, is another set of gears from pto back to bottom, and they must be using a pinion shaft coming in from the back to drive the crown ring gear. If that drive going back to rear end has a clutch, then that clutch could give Live PTO while in creeper. I suspect it only has one creeper speed and that one must leave transmission in neutral while using.
I post this photo ocasionally, hoping someone may recognize the unit and can tell us more about it, how many are around, where they are at, etc. Yes I to would like to know more.
Bruce Wa.
01-05-2008 19:01:54
 Re: Creeper Gear Offset Farmalls in reply to Hugh MacKay, 01-04-2008 03:01:42
Hugh,
I've seen these around here before. I'm not surprised you don't see them where you are. What it says on the gear box is Ray Bock equipment company which was our local dealer in Puyallup,WA. It was the place I loved to go with my dad when I was a kid. There were a lot of lettuce and fresh produce farmers in the area back in the 40s, 50s, and 60s and I guess they needed a slow gear. They probably had those built here in the Seattle Tacoma area. A friend of mine has a 140 with this on it and it was sold new at Ray Bock. This same building and site is a Kubota tractor dealer today.
Hugh MacKay
01-06-2008 01:43:54
 Re: Creeper Gear Offset Farmalls in reply to Bruce Wa., 01-05-2008 19:01:54
Bruce: Thank you for this information. I don't know if you noticed, however Steven started another thread on Tractor Talk page, and there is a guy over there came up with the same information.
Earlier in the evening I had typed in on google Ray Bock Foundry. I found that the Bock family had and still do have foundries. I also found info on several family members including a Kenneth Ray Bock Sr. associated with the foundry business. He had a son Kenneth Ray Bock Jr., however no mention of what business ventures he may have been involved in during his lifetime. He was however born in the mid 1930s, making him about the right age to have established a farm equipment business in the 1950s. This gear box was obviously done quite professionally in a foundry, and if he is the same Ray Bock this would explain his access to those foundries.
I am going to respond to your e mail as well. Again thank you for coming forward.
Bruce Wa.
01-05-2008 19:41:35
I looked at the picture again and noticed the second line says"Puyallup Wash."
Steven f/AZ
01-05-2008 07:05:23
 Re: Creeper Gear Offset Farmalls in reply to moseed, 01-04-2008 03:01:42
Hugh MacKay said: (quoted from post at 07:35:58 01/05/08) Steven: I just wish I could make out that lettering. I was hoping young eyes like you or Sam could read what it says.
Furthermore I wish K-Mo would chime in with his opinion. Even if he can't post a photo at least he could say yes or no, as to whether this is the same gear box as his Auburn Trencher.
I just can't make out anything more than "Bay" because the shadows and blurriness of the picture takes out the rest...
Could you email me the original? I suspect it might have been downsized when uploaded to YT...
Steven f/AZ
01-05-2008 05:15:32
Hugh, this is the best I can do right now as far as zooming in and blowing it up. It appears on the left side there may be something different on that final drive? It's been so long since I've been around our A I don't remember...
Please email me the original, maybe it has more pixels and will show up more clearly when stretched...
third party image
third party image
Hugh MacKay
01-05-2008 06:35:58
 Re: Creeper Gear Offset Farmalls in reply to Steven f/AZ, 01-05-2008 05:15:32
tractorsam
01-04-2008 16:18:05
Just a suggestion - If the power came in through the top (as it ordinarily would to the PTO) then by gear drive to a lay shaft (which in this case you see as having the PTO sticking out the rear) and then that layshaft drives the lower shaft (which would have a pinion on to drive the crown gear) via another gear set. According to my parts book the reduction for the PTO is almost the same as the reduction for 1st gear. If this box used two sets of PTO gears it would be something like a double reduction. Also for those who are more skilled with computers there appears to be some writing arranged around the PTO shaft in a semicircle (beginning with BAY?), can this be blow up or clarified? tractorsam
Hendrik
01-05-2008 15:41:26
 Re: Creeper Gear Offset Farmalls in reply to tractorsam, 01-04-2008 16:18:05
On a Super A, the PTO shaft in its original position is in line with the output shaft of the transmission. Distance between input shaft and output shaft of tranny is 4 and 3/8 inches.
So, what Tractorsam suggests could work and the use of an intermediate shaft (the "new" PTO shaft in this attachment), would also make the tractor move forward, as is proper.
But this does not answer your original question :-(
Steven f/AZ
01-04-2008 10:26:38
K-Mo, please post any pictures you have! If you are unable to post, you can email them to me at smgussey at yahoo dot com and I will host them for you... I'm interested to see these!
And here is the pic that Hugh has posted to the site:
third party image
Hugh MacKay
01-05-2008 03:38:03
 Re: Creeper Gear Offset Farmalls in reply to Steven f/AZ, 01-04-2008 10:26:38
Steven: Thanks for moving the photo over here. I've really never put a lot of effort into posting photos on discussion pages, thus when the time came, it didn't work.
I wish K-Mo would come back with his photo, even comments. I don't think it is the same device. At least I can't imagine an external shaft from the device in my photo bypassing the transmission.
I've also seen a two speed gear box designed to fit in the torque tube of a Super A. Then there is the IH two speed gear box designed for use in the torque tube of the 404. That one should work on an offset, however I expect one has to use the 404 torque tube. Problem with both of those devices, they also reduce PTO speed when in low side. It may be time to start a new thread, inviting guys to post photos of creeper gear devices for offsets. I'd also like to get to the bottom of this one in the photo, and as Sam states there is cast in place print on the gear box. Hopfully someone can do as Sam suggests. I had a guy, seeing this discussion, ask me yesterday where the photo was. He was interested in learning more. I think we should take this a few steps more, so many times items like this gear box seem to die without resolve.
Hugh MacKay
01-04-2008 09:54:30
 ATTENTION photo of this in Help Identify in reply to Hugh MacKay, 01-04-2008 03:01:42
There is a photo of this Creeper Gear in Help Identify photo gallery. If anyone recognizes this device, I'd like to know more about it.
K-Mo
01-04-2008 08:26:43
For creeper and PTO this is what I know.
1- Hub City made a reduction gearbox for the Farmall Cub to provide a 540 RPM CW PTO.
2- An IH creeper option was a hydraulic motor attached to the PTO and operated with the transmission in neutral.
3- Auburn Trenchers were installed on the Farmall Offsets. These used a gearbox installed between the clutch housing and the transaxle case. On my 140, this provides for two creeper ranges and provides a PTO which extends from the gearbox and routed under the transaxle case to drive the trencher.
None of these provide an IPTO.
K-Mo
Hugh MacKay
01-04-2008 09:37:02
 Re: Creeper Gear Offset Farmalls in reply to K-Mo, 01-04-2008 08:26:43
K-Mo: I should have been more specific, look at the photo I posted in help identify yesterday. This unit is for SA, 100, 130 or 140. I know all about Hydra Creeper drive, definitely not that.
Does it look anything like the drive for your Auburn Trencher. I ask this as this unit as bolted to the back of a offset could hide a shaft going under the transaxle. I'd be interested in your opinion as I've never seen an Auburn Trencher on and offset Farmall.
I've had this photo close to 4 years now, each time I post it no one seems to know the device or how it works. The description given to me with the photo, was power was transmitted from top shaft to the shown PTO shaft then back to the rear end via the lower shaft. I have never been able to contact this individual to ask more questions. I you can solve it, that would be great.
LA in Wi.
01-04-2008 07:56:57
Hugh,
I have a brother-in-law who was born in creeper gear. Does that help you?
LA
Dan-IA
01-05-2008 10:58:26
 Re: Creeper Gear Offset Farmalls in reply to LA in Wi., 01-04-2008 07:56:57
I was born in creeper gear too. Lots of torque and pull, but damned little speed.
Hugh MacKay
01-04-2008 08:17:41
Lowell: I'd have to see him move before making a judgement call on that one. Is he as slow as a worker my dad once hired to do some hoeing. Dad told him he'd have to drive a row of fence stakes 4' apart to see if he was actually moving along the row.
