cooling problem
w bowley
01-04-2008 13:35:21
444 ih over heats appears not to be circulating water pump good thermostat good
FromJB2
01-05-2008 05:54:01
 Re: cooling problem in reply to w bowley, 01-04-2008 13:35:21
I would check coolant flow thru the rad. Take the bottom hose off the rad and pour water in the top and check the flow coming out the bottom.
Had 454 that would over heat..changed water pump..thermostat..even totally removed thermostat..still overheating. Solution was to have rad steam cleaned to get all the crud out of the rad cores.
JimB
El Toro
01-04-2008 18:34:13
Could the radiator tubes be plugged? This could restrict or prevent the coolant from circulating
through the radiator. I wouldn't run the tractor until you find the problem since you could damage the engine from overheating. Hal
PS: That permanent antifreeze will plug a radiator when it loses its rust inhibitor.
w bowley
01-04-2008 17:38:55
 Re: cooling problem in reply to SuperA-Tx, 01-04-2008 13:35:21
w bowley said: (quoted from post at 01:09:08 01/05/08)
w bowley said: (quoted from post at 22:35:21 01/04/08) 444 ih over heats appears not to be circulating water pump good thermostat good
water pump was of appeared to be good ,water sounds to be boiling even after motor is off, could there be a blockage in the head?
I have no experience with head gasket leakage but I have seen how a cracked head effects operation
karl f
01-04-2008 16:35:16
have you looked at the impeller itself? on our swather with the c-153, it always over heated easily, replaced the head (cracked), replaced the radiator, finally years later the waterpump bearings went out and when it was taken in to rebuild, there was no impeller left just a clump of rust! has never overheated since.
karl f
w bowley
01-04-2008 16:09:08
 Re: cooling problem in reply to richardinnz, 01-04-2008 13:35:21
Brownie450
01-04-2008 15:53:17
Could the impeller be loose on the shaft?
Andy Martin
01-04-2008 14:40:46
First step: loose belt?
Second step: stuck thermostat?
Third step: internal hose obstruction?
Fourth step: Bad water pump?
