IH 986 compatible with 1066
Mel Shaw
01-05-2008 08:05:47
Will a 986 bolt up at clutch housing of a 1066? Front end and rear end.
Owen Aaland
01-05-2008 19:07:35
 Re: IH 986 compatible with 1066 in reply to Mel Shaw, 01-05-2008 08:05:47
If you are asking if a 1066 clutch housing will fit in a 986 the answer is no unless you have a very late model 1066. All but the last ones did not have the provision for the 86 series cab mounts. 86 series housings will work on the 66 series but usually nor the other way around.
mkirsch
01-05-2008 16:48:09
 Re: IH 986 compatible with 1066 in reply to dave guest, 01-05-2008 08:05:47
The bolt pattern from engine to bell housing is the same.
However, everything on top is different from one to the other. The steering column, instrument cluster, operator's platform, etc. are very different.
Your path of least resistance will be an engine swap. Just take the good engine and put it in the tractor with the good transmission. It'll bolt right up like nobody's business, and you won't have to futz with trying to figure out which parts need to be changed.
Fred the Swede
01-05-2008 15:29:40
The clutch is bigger on the 1066 and itīs another flywheel, but it will bolt up.
Allan In NE
01-05-2008 09:20:38
You'd sure think so. They are pretty much the same tractor in that department, aren't they?
Allan
