Farmall C govener
dougie94
01-05-2008 10:32:37
I tryed to take off my govener on my 49 C,I removed the mag and the 4 bolts from the front.The unit moved some but would not slide off.What am I doing wrong and what do I do before i take it off any marks or something I should refernce?
tractorsam
01-05-2008 13:02:42
 Re: Farmall C govener in reply to dougie94, 01-05-2008 10:32:37
Have you got both the linkage from the throttle lever and to the carburator disconnected? tractorsam
dougie94
01-05-2008 14:59:54
 Re: Farmall C govener in reply to tractorsam, 01-05-2008 13:02:42
yes both are off
tractorsam
01-05-2008 17:53:09
 Re: Farmall C govener in reply to dougie94, 01-05-2008 14:59:54
Sorry, had to check, sometimes I overlook the simplest things and then end up kicking myself. Other than the (I think at least five) bolts that secure it it should come straight off. Do you have the rad off the tractor? If not it is a little more difficult to wiggle it off there. tractorsam
gene bender
01-05-2008 12:05:59
When you get it loose be sure you dont remove or get the gear moved or you will get the timing off and have a mess. Just be careful removing the gov it will come out but aint easy.
ShaggyM
01-05-2008 10:45:52
There are more than 4 bolts. I think there are 5. 2 on the top a long and short and one on the side (to the outside of the motor)and 1 on the bottom and 1 on the fan side. The short one also is one of the bolts that hold on the temp gauage if you have one.
