H Distillate Manifold
John - OH
01-05-2008 14:31:33
I would like to remove the heat damper "flapper" from my distillate manifold. I was wondering if there is a pin of sorts to hold the shaft in the flapper or is it a press fit. The parts book I have shows an external collar and pin with a straight flapper. The one in my manifold is L shaped and has no external collar. Manifold is part no 6712DB. I just don't want to break anything. Thanks in advance.
Gauger
01-07-2008 05:49:38
 Re: H Distillate Manifold in reply to John - OH, 01-05-2008 14:31:33
I would keave it alone. If you have a manifold with a working heat valve you are very fortunate. I have a distillate SH and have been going to great lengths to salvage the manifold. I think you will find the cast iron to be marginal for welding from the inside. I had a crack welded from the outside on mine and after a little dressing with the grinder it is not noticeable. The key is to find someone who knows how to weld cast iron. I had mine butchered by a "pro" before I found the right guy. The valve is pinned but even if you get the pin out I think you will find it difficult the drive the shaft out of the valve without breaking something. As others have sai, these hot box castings are fragile.
John - OH
01-06-2008 07:23:08
No the flapper is free and working, but there is a small hairline crack up the side. Thought it would look better welded from the inside, but maybe it isn't worth taking the chance of breaking it. John
John M
01-06-2008 06:07:44
Why? Is it stuck closed?
Kristof
01-06-2008 05:27:10
I wouldn't do it. Those things break rather easy. I tried on mine, but now I've ended up with a shiny new one :)
Kind regards
rls_ia
01-06-2008 01:45:18
The flapper in mine was in bad shape so I just took a hammer and punch and broke it off.
Those manifolds get weak and thin, be careful
Bob
karl f
01-05-2008 22:16:33
bet you can pay for almost two gasoline manifolds for the price you could get for your working distillate one.
karl f
Fancy Farm
01-05-2008 14:36:40
Buy a new replacement gas manifold for it. They weren't ment to take apart/
Tom Windsor
01-05-2008 20:26:42
 Re: H Distillate Manifold in reply to Fancy Farm, 01-05-2008 14:36:40
I agee. You are going to wind up with a leaky manifold after you get through doctoring this one.
tw
