IH 574 flywheel
Lawrence Grevel
01-05-2008 16:33:36
Looking for specs for the IH 574 flywheel. I need to know the distance from the shoulder where the pressure plate bolts to the clutch plate flywheel surface. Thanks for any help!
richardinnz
01-05-2008 18:57:16
 Re: IH 574 flywheel in reply to Lawrence Greveling, 01-05-2008 16:33:36
When you are refacing, don't forget to take off the same amount from where the flywheel to crankshaft bolts go in, the clutch plate hub will foul the bolt heads when it gets part worn.
RickB
01-05-2008 16:53:30
  574 flywheel step dimension in reply to Lawrence Greveling, 01-05-2008 16:33:36
Courtesy of HyCapacity's website; 1.443".
