Re: 560 diesel fuel pump
Owen Aaland
01-05-2008 18:58:22
If you are talking the pivot arm shaft there is a small o-ring on each side of the case under the cap nuts. They can be replaced without removing the pump. If you are talking about the throttle shaft it is more complicated. Those o-rings are on the shaft so some disassembly is required.
