Original F-20 spark plugs and wires
Scott Rukke
01-05-2008 20:32:58
What were the original spark plugs and wires for the F-20? Are they still available or are their any good repos? I see a lot of them that have the open end terminals on the plugs.
Bob Kerr
01-06-2008 09:03:47
 Re: Original F-20 spark plugs and wires in reply to Scott Rukke, 01-05-2008 20:32:58
I had 2 10-20s with original wires. They are black rubber soild core wires with brass loops on the spark plug end. I never saw any writing on them, but they could have when new, hard to say on that. The original sparkplugs used flat knurled nuts to hold the wire on. The nuts were originally nickel plated but most you"ll find have worn down to brass.
Bob Kerr
01-06-2008 09:24:14
 Re: Original F-20 spark plugs and wires in reply to Bob Kerr, 01-06-2008 09:03:47
I should add the ones I mentioned above may be right for Regulars and not so much for F-20s. I think my f12 has original wires on it and they are cloth covered and have 90 deg elbows on the end with no insulation on the metal ends.
kfox
01-06-2008 05:48:08
Here is another place to get origional wire & connectors.
Link
Nebraska Cowman
01-06-2008 05:26:09
The original was a Champion 20, The replacement today is a W20. Yeah, I have bought stuff from John Brillman.
oldiron29
01-06-2008 04:54:26
Scott, John Brillman will have all electical part
Mag, point, caps, plugs, wires, ECT. www.brillman.com He has helped me with mag rebuilding over the phone. Good guy! oldiron29
Paul G. in Mn
01-06-2008 04:41:36
I got the plug wires for my F-20 from www.thefordsonhouse.com
was resonable priced and shipped quick
F-Dean
01-06-2008 04:36:00
I believe that the original spark plug was a Champion W-20. However, I have had much better results with Autolite 3077. They look a little different but work well! They are available on line from Advance Auto Parts.
SproutW
01-05-2008 21:19:14
WWW.brillman.com
They have reproduction wires.
