IHC 806 Injector pump
Gavin Kedar
01-05-2008 21:33:10
We have a 1964 IHC 806 with IHC injector pump. Dealers here in Australia tell me the parts are not available to repair pump & to convert to a roosamaster. Any ideas as to if parts for IHC pump (particularly seals) are available in USA?. It is still working well, plenty of power, just seals are getting old & new diesel causes them to weep. Worst weep is on block side of pump, hard to see. Any one ventured there before, & can tell me what could be leaking there?. Regards, Gavin Kedar.
Paul Graham
01-06-2008 11:35:17
 Re: IHC 806 Injector pump in reply to Gavin Kedar, 01-05-2008 21:33:10
Hi, give Ken Updike a call at Carter & Gruenewald in Wisconsin, they are a well know and trusted IH dealer. >Link
Best of Luck.
ejr-IA
01-06-2008 10:57:53
Their are places that fix the RD pumps yet.
Matt from Oz
01-06-2008 01:45:26
Gavin parts are available for much IH stuff in the USA. The support is incredible I have souced stuff for a recent 1944 IH resto job from the US to Australia. I used Carter & Gruenewald in Wisconsin, They will forward parts, many others don't deal with outside continental US. I also sourced parts from local case IH dealer in NSW once I had the correct part numbers. Keep trying you should be able to get these, you may need to try another dealer. Matt
