f12?
tim bynum
01-06-2008 08:57:14
can someone tell me what model this is? a f12 or 20? it is a wide front what i really want is a steel wheel.
LenNH
01-11-2008 12:38:20
 Re: f12? in reply to tim bynum, 01-06-2008 08:57:14
F-12 for sure. Hard to tell from pix if steering wheel is rubber. IH put rubber steering wheels on about 1937, I think. They usually cracked and then the rubber fell off the spokes. Some people went and got an older 4-spoke iron wheel (that could be the case here, but the picture is not sharp enough to tell), some people put on wheels from A or H. I had an F-20 with one of those wheels, but it was a sloppy fit. Your round spokers were available from about 1936 on, I believe. Don't think they are terribly common. Great majority of these tractors probably sold on steel, then cut off to weld on rims. Then, just before F-14 came out, the tractor was available on cast-iron wheels, like the '38 my father bought and which I used for years. Can't tell if this tractor has a power lift, but that would add interest if it does. The pump drives off the left side of the pulley shaft, and sends the fluid up the flat "pipe" from the pump to the lift.
Steven f/AZ
01-06-2008 09:22:12
Definitaly F-12...
The F-20 & F-30 had drop gear boxes on the rear, and F-14 had a raised steering wheel, giving an angled shaft.
FWIW I don't think that wide front looks factory, but it's hard to tell on a side view.
Bob Kerr
01-06-2008 09:11:03
F-12 gasoline only version. Those wide fronts are worth a huge bundle! and the round rear spokes are too in good shape. You may have found a real prize!
