Farmall A question ??
Eben Merrill
01-06-2008 10:44:37
I was pushing up the snowbanks with my Farmall A today, and I noticed that the right rear wheel was spinning when I got on ice, and the left wheel did not turn; should both rear wheels be turning even though one is spinning? Do I have a left rear axle problem? Thanks, Eben in Vt.
dave guest
01-06-2008 12:06:22
 Re: Farmall A question ?? in reply to Eben Merrill, 01-06-2008 10:44:37
Anybody got a posi-traction kit?
Andrew Z
01-06-2008 12:10:42
 Re: Farmall A question ?? in reply to dave guest, 01-06-2008 12:06:22
the old Miller Locker will do it lol (welding the spider gears together) There are no kits that are out there to make them haave a true diff lock like in more morden tractors if thats what you mean.
Andrew
Andrew Z
01-06-2008 10:50:04
Every thing is normal there, its the how a differental works. If your loose traction and see one wheel spining hit that side brake and the other wheel will spin. But there is nothing wrong with your A :)
Andrew
Eben Merrill
01-06-2008 11:36:45
 Re: Farmall A question ?? in reply to Andrew Z, 01-06-2008 10:50:04
OK, thanks! I really should put on my chains!!!
