Farmall Plow
DonNOhio
01-06-2008 17:27:32
third party image
Any one have info on this 2-14" plow? Looks as it was converted to 3 point. It fits on my SC.
Thanks.
Hugh MacKay
01-06-2008 18:13:12
 Re: Farmall Plow in reply to DonNOhio, 01-06-2008 17:27:32
Don: Your plow may look converted, that is because IH used the same plow frame for 3 point as for fast hitch plow. If it fits and those fast hitch forks enter the receivers to the latch point of your SC, they must be small fork hitch.
The plow bottoms are IH GP bottoms and there are some variation with those. If ordering wear parts, you will need current part numbers.
D Slater
01-06-2008 17:59:45
Forgot to say that I think its a model UF-20.
D Slater
01-06-2008 17:49:05
It has the top link for a 300 utility but the fast hitch points should be to big for a SC unless ground down.
Janicholson
01-06-2008 17:41:51
It has stock points and mounting and trip tip up release hardware identical to that on other IH plows of that era. I do not know the model # but it is probably a Plow Chief. JimN
