Demagnitization Magneto
Kristof
01-07-2008 09:21:16
I was wondering, since I put 12volts on my magneto (by mistake, see previous topics starting problems).
Could it be that I have demagnetized my magneto?
Kind Regards,
Kristof
El Toro
01-07-2008 14:35:53
 Re: Demagnitization Magneto in reply to Kristof, 01-07-2008 09:21:16
Pull the coil wire from the cap and hold it near a good ground while someone cranks over the engine. Make sure the grounding switch is in the run postion too. I would worry more about the coil or condenser than the magnets being hit with battery voltage. Hal
Andy Martin
01-07-2008 12:13:54
I thought you said you still had a spark.
Spark=Working Magneto
gene bender
01-07-2008 11:15:22
Just unhook a wire and run it to another spare plug that is grounded and turn over with starter and you will soon see if there is any spark.
Nebraska Cowman
01-07-2008 09:54:42
I doubt it but you may have cooked the coil or condenser etc.
oldiron29
01-07-2008 09:30:19
Kristof, Call John Brillman 888-274-5562 the Brillman Company he is good with mags. oldiron29
