Spool valve plumbed up backwards, maybe?
mkirsch
01-07-2008 09:54:35
I'm putting a TwinDraulic loader on a Cub. It came with a one-way Gresen hydraulic valve that didn't have the IN and OUT ports labeled.
The loader drops slightly before it starts to raise, and there's a funky vibration in the whole tractor as it raises.
Could it be that I have the ports plumbed backwards? I'd change them around, but I don't want to make the mess unless I'm reasonably sure that it'll solve the problem.
mkirsch
01-08-2008 06:36:49
 Re: Spool valve plumbed up backwards, maybe? in reply to Too Far Gone, 01-07-2008 09:54:35
Hmm, I have it plumbed correctly then...
There is an external reservoir plumbed up to the fill plug for the one-way cylinders, and that is vented to open air. If I remove the fill plug, I will end up with about a gallon of Hytran on my pants :)
I've done several cycles of the loader, and it's only getting worse...
RR Mech
01-07-2008 20:14:32
 Re: Spool valve plumbed up backwards, maybe? in reply to mkirsch, 01-07-2008 09:54:35
All of the gresen hyd. valves I have ever seen have the inlet on the left side as you are looking at the lever end with the Cylinder hoses going up.Hope this can help.
georgeky
01-07-2008 15:07:51
Sounds like you have air trapped in the system./ Try leaving the fill plug out of the resivoir and work loader up and down a few times.
