farmall a oil pump
nspec
01-07-2008 12:57:07
Hello all. I"m looking for the oil pump cover (part #6098 D) for a Farmall A. When I took the oil pump out to reface the cover in the hopes of getting a little better pressure (it was in fact worn), I noticed that it was pitted, or broken in several places around the outside edges. Looks like this piece is aluminum and it is severely pitted. Anybody seen this before?
Also need the gasket (43415 D) to go with it, or perhaps a suggestion on what to use for a gasket. What came off was an extremely thin paper type gasket.
Other than that, pump is fine, so I really don"t need the whole thing. Any help would be greatly appreciated.
Thanks in advance!
ihfan32
01-07-2008 17:36:38
 Re: farmall a oil pump in reply to nspec, 01-07-2008 12:57:07
that cover is still avalible, last i knew it was around $110 for it.
glennster
01-07-2008 14:11:59
i checked on the case i-h website, the part is still available new, also, the gasket is part number 43414d, that shows its still available also.
nspec
01-07-2008 14:47:41
 Re: farmall a oil pump in reply to glennster, 01-07-2008 14:11:59
Not to be a pain, but the oil pump cover is listed in red on the CIH site with no check box. I believe it is not available from them any longer. The gasket is.
Bates shows they have one. Anyone have any luck with them?
glennster
01-07-2008 14:53:08
 Re: farmall a oil pump in reply to nspec, 01-07-2008 14:47:41
i have bought from bates before, they are good people to deal with. i did check with the local dealer last year for the same part for my farmall b, same pump, they said it was still available, around a hundred dollars or so.
nspec
01-07-2008 15:05:00
 Re: farmall a oil pump in reply to glennster, 01-07-2008 14:53:08
sounds good. thanks for the info. did your part have the pitting/broken off pieces? i was sort of wondering what causes that.
Kristof
01-07-2008 13:34:59
Had the same problem with my C.
The cover was warped pitted and worn down. The best way to save it is by polishing the cover with wet sandpaper. You put the sandpaper on a mirror or on any other surface that you know is perfectly flat and lock it in place. You put some white spirit or water on it and you start polishing the cover in an 8-shaped motion untill your cover is completely blank. This way it will seal up nicely. The best way to seal you pump is with sealing paper about 0.8mm thick. I used this trick on my pump and I've got to say, works like a charm :).
Kind Regards
nspec
01-07-2008 13:41:07
 Re: farmall a oil pump in reply to Kristof, 01-07-2008 13:34:59
what exactly is sealing paper, and where does one get it?
as for the sanding, that is exactly what I was planning on doing, only that piece is badly broken, ie: missing chunks of material, around the outside and I'm just afraid it will leak or break in the future. I'd like to replace it with an undamaged cover, even if I need to sand that one to make it right.
Kristof
01-09-2008 10:33:54
 Re: farmall a oil pump in reply to nspec, 01-07-2008 13:41:07
Sealing paper is just joint-paper where you can cut out the desired shape of joint :).
Well, I don't know how badly damaged your cover is. As long as It's able to seal around the edges I don't think there would be a problem? Mine was chipped also around the edges but there was still enough material left to seal the pump.
DON'T try to use liquid-jointing or silicones on your pump! It has the nasty habbit to creep inside you gearworks, makes it's way up and, well I guess you know what I mean.
Hope I could help
Kind Regards,
teddy52food
01-07-2008 14:05:57
If you can't find that part, take yours to a welding shop that does aluminum and get it built up before sanding. It may last another 50 years. Try without a gasket. Keep turning as you tighten the bolts . If it gets tight put in the gasket. If not you are good to go. There may be enough clearance wear in the gears to run without a gasket.
Jack OH
01-08-2008 04:30:48
 Re: farmall a oil pump in reply to teddy52food, 01-07-2008 14:05:57
The gaskets are what determine the clearance between the cover and gears. Keep that in mind when selecting the new gasket material, I would use new original gaskets, it is hard to make your own gaskets that thin. Sometimes you need two gaskets to get the correct clearance.
Jack
