Order Farmall Cub Parts Online
YEAR OF INTERNATIONAL CUB LOBOY
Bob Coles
01-07-2008 13:25:21
AM CONSIDERING THE PURCHASE OF A TRACTOR TO RESTORE BUT CAN'T DETERMINE ITS YEAR
ON BOTH SIDES OF ENGINE COVER IS "INTERNATIONAL"
ON A ROUND DISK ON EACH SIDE OF THE RADIATOR IS 'LOBOY".
ID PLATE READS "MODEL AF CUB" SERIAL NO 21433.
ON LOWER SIDE OF BLOCK "251341R7" (NOT SURE OF R7.
ON LEFT SIDE OF TRANS "360719 - R1.
IT IS 6 VOLT.
Jim Becker
01-08-2008 12:45:43
 Re: YEAR OF INTERNATIONAL CUB LOBOY in reply to Bob Coles, 01-07-2008 13:25:21
Your informaton is a bit in conflict with itself. Your serial number says '66 but the the "MODEL AF CUB" part of it looks slightly misread. The round (actually oval) disk on each side of the radiator says '58-'63. Electrical systems got changed from 6 to 12 volts in '64. Your R7 (if correct) was only used until '64. A '66 model would be R8.
I wonder if the tractor is in the '58-'63 range and the serial plate was installed along with a replacement front bolster.
Look here for more details:
Link
tennhillbilly
01-07-2008 16:02:15
According to the serial # here on this site , Looks like it would be a 1966
Bob Coles
01-07-2008 16:21:59
 Re: YEAR OF INTERNATIONAL CUB LOBOY in reply to tennhillbilly, 01-07-2008 16:02:15
Thanks.
