3 PT leak down on 1466
61-4010
01-08-2008 10:51:35
Greetings. 3 point on my 1466 leaks down after awhile with the motor turned off. Holds fine when running even with a load. But when she is turned off, eventually she drops. Normal? And if not, is it time for a rockshaft rebuild?
Hugh MacKay
01-08-2008 15:48:10
 Re: 3 PT leak down on 1466 in reply to 61-4010, 01-08-2008 10:51:35
I had a 1066 and it leaked down not running from the day it was new. Did it for 15,000 hours, never any better, never any worse.
Janicholson
01-08-2008 15:28:53
The older ones know that leaving their tail up is an invitation that is too suggestive.
If you leave them down, less pressure is exerted on the seals and components. They are never pull started anyway. JimN
Allan In NE
01-08-2008 11:15:11
Years ago, I used to buy new tractors. They never leaked down, ever.
Now with this second "used machinery" go-'round they will all leak down. Every blessed one of 'em. Totally rebuilt one of the rascals from the eye sockets up and it still does it. :>(
Ignore it. Think it is just pouting and trying to get yer attention. :>)
Allan
bbelltn
01-08-2008 19:35:14
 Re: 3 PT leak down on 1466 in reply to Allan In NE, 01-08-2008 11:15:11
My rule- If it doesn't leak down with the engine running, don't bother!
