300 and 350U
Bill46
01-08-2008 12:58:33
Ok all you educated folks...need a little help here.
Brought in another 300U for parts last night. Man told me to get the darn thing out of his way.
Typical old tractor...motor stuck from setting in a corn crib, rotten tires, seat rotted off but it's all there...no missing parts. You know the drill. But it has a good set of split Utility rear wheel weights and a power sterring unit so I brought it home. When I got it in the light...I started seeing differences than the rest of the herd.
The PTO rear cover is flat. Looks like the PTO comes out of a flat plate with bolts. The others have what looks like a ring around the PTO shaft plate. The fast hitch is totally different than the other 300/350U tractors I have...and I have a mess of them. The top of it has an arm that comes up fron the bottom and looks different than the lift on the others. I know the 350Us are totally different...but this thing is strange looking. It looks much stronger...the metal is much thicker and heavier.
The thing has 6 control valves on it...one for the fast hitch and 5 more. I thought 3 was the limit.
It has a much bigger hyd pump on it.
The clutch linkage is totally different that the other tractors...both 300 and 350Us. Looks strange.
Now...all the parts have IH on them so I know they are not after market...but what do I have?
Could it be an industrial version? It's red...but I thought they were all the same.
Any ideas? Any help is appreciated.
D Slater
01-09-2008 02:55:43
 Re: 300 and 350U in reply to Bill46, 01-08-2008 12:58:33
Only thing that comes to mind is your pto has the regular or row crop rear cover and the rest have the rear cover that a belt pulley gear box can bolt to. If the pump mounts on the engine I don't know of a bigger one, so wonder if someone may have installed a aftermarket pump. Where does the ports on pump exit, up, down, or other? Need more info about hitch. If you have 300 and 350U you should have 2 types of hitches already. Are you saying the hitch is different from the 2?
CNKS
01-08-2008 17:59:21
As Wardner said get a parts book, or look at the diagrams on www.caseih.com. You will probably be surprised at the options. I have a 460U, the 350U replacement -- there is a 3 point option for the industrial, which do have differences. But, I don't have a 300/350U, you have several --
Wardner
01-08-2008 16:15:26
I can't help
If you have so many 300-350 utilities, I am surprised you don't have a parts book. One book probably covers both models and all the various attachments.
Bill46
01-09-2008 04:54:29
 Re: 300 and 350U in reply to Wardner, 01-08-2008 16:15:26
Yes...I have a parts book...but this junk is not in there.
The pictures look about the same...but more like the others I have.
The pump is much bigger. The distrubator sets back a little farther from the front of the engine and the hyd lines are shorter.
Yes...I do have a herd of utilities...more than a sane person would want...but I cannot pass the darn things up if the price is right...and I hate scrap yards. Heck...one of you guys may need something I have no use for one day.
Dad had both 300s and 350s when I was a kid. That and a Super MTA Diesel were his main tractors when I was young. Maybe I will get the other half to help me this weekend and I can post some pictures for you. Sure caught me off guard because I thought I knew all about this Red stuff.
