F12 Governor
teddy52food
01-08-2008 15:38:59
Is it normal for the governor to respond slowly? When I start it up it seems to rev up quite high before it shuts down. All the linkage is free with not too much slop. I am used to the B and C , maybe this is normal on an F12.
LenNH
01-10-2008 09:33:38
 Re: F12 Governor in reply to teddy52food, 01-08-2008 15:38:59
Never fixed one of these, but I agree that it was a very responsive governor, and certainly should control the speed immediately. Drove one for 12 or 15 years.
Ron Weber
01-08-2008 20:15:00
No. It shouldn't. I have always felt that the F-12 governors were the most reponsive of all the tractors I have had the pleasure of driving. Either it is gummed up in the tower or there are balls missing/worn out in the housing---pull the side cover off and check it out before it runs away on you.
teddy52food
01-09-2008 06:05:51
 Re: F12 Governor in reply to Ron Weber, 01-08-2008 20:15:00
I had it all apart when I rebuilt the engine and remember replacing 2 small bearings in the tower. The old spring was bad & I got another assembly on E Bay. Is there an adjustment procedure I am missing? The thrust bearing was ok.
teddy52food
01-09-2008 06:04:55
James Williams
01-08-2008 17:12:50
no
