Finaly found it now what else do i need
Pat-CT
01-08-2008 17:29:38
thanks to a member the other day i found the brillman co which has the bracket need for the farmall H to mount a 12 v alternator to it before i order anything im going to total up everything i need to alternator batery and bracket but what else do i need for a 12 v conversion
Gary in Mozarks
01-09-2008 09:35:44
 Re: Finaly found it now what else do i need in reply to Pat-CT, 01-08-2008 17:29:38
The labeling is the confusing part. A 6v coil and a 12 external resister are the same thing. The explaination you are leaving out is that the points don;t like 12v, It causes arcing and early point failure. Points work best at 6 volts, 12 volt systems generally use a step down (ceramic) resister to lower it to 6volts. This works out good, in that they can sidstep the resister to feed 12v to the coil during the start mode for a hotter spark, the drop back to 6 volts for the run phase. (so you don;t burn up the points) internal resister coils can not do this. Even though you run 12volts in they step it down internally and run 6 volts in all the time and therefore do not start as easily.
Pat-CT
01-09-2008 04:06:20
Napa has the coil but i dont think its the same power as the ones on this site do theones on this site need a resistor
Hugh MacKay
01-09-2008 02:41:23
Pat: Just speaking from personal experience, take Bob's advice go and get that true 12 volt coil. It will save you from uttering four letter words.
karl f
01-08-2008 20:43:32
i'm in the same boat as you for converting our machines. with lack of a shop/garage, welder, welding experience, etc.; i am very limited in the fabrication department. the electrical side usually scares the average person, but for me it's the fabrication. i think i could do the electrical in my sleep if i had to lol. many of the pre made brackets are not worth the price either, hope this one was.
thanks for sharing your find,
karl f
Pat-CT
01-08-2008 18:56:14
eh nvm ill get a resistor ....but if its a 1 wire alternator does that mean it has like an internal regulator ..thanks for you time by the way i really appreciate it
Pat-CT
01-08-2008 18:29:36
what if i got a 12 coil?
CNKS
01-08-2008 18:34:33
 Re: Finaly found it now what else do i need in reply to Pat-CT, 01-08-2008 18:29:36
Then you have to get one with an internal resistor or use an external ballast resistor.
CNKS
01-08-2008 18:50:10
 Re: Finaly found it now what else do i need in reply to CNKS, 01-08-2008 18:34:33
But, there is some confusion about this. IF you can find a true 12 volt coil, you "may" not need the resistor. I have a 460 with a factory 12 volt system. It used a coil with a ballast resistor. In trying to get it started after an overhaul, I fried the coil due to sutpidity. I replaced the coil with a 12 volt coil with an internal resistor. Many articles in the archives about this. I have yet to hear a satisfactory explanation that I understand. All coils are not created equal, you have to know what you are buying.
Bob
01-08-2008 19:58:04
 Re: Finaly found it now what else do i need in reply to CNKS, 01-08-2008 18:50:10
A "6-Volt" coil, and a "12-Volt" coil that is marked "use WITH external resistor" are more or less the same thing.
MOST TRUE 12-Volt coils have more primary windings, and are able to operate properly on a 12-Volt system with NO external resistor.
NAPA coil part number 14SB is ONE example of a TRUE 12-Volt coil.
CNKS
01-08-2008 17:37:12
Bulbs and a resistor for the coil. Be sure you get an alternator that will fit. With some full size alternators there is zero clearance between the hood and the alternator. Perhaps that bracket takes care of that, I don't know.
