Farmall M hand crank Shaft
Zach Bouchard
01-08-2008 19:21:50
My Farmall M"s Hand crank shaft has been broke off and rewelded. It probobly doesn"t need to be replaced but I am restoring it and would like to do it before I paint. How do Iget it out? I have looked at it and I haven"t figured it out. How do I get it out and back in?
Nebraska Cowman
01-09-2008 04:56:49
 Re: Farmall M hand crank Shaft in reply to Zach Bouchard, 01-08-2008 19:21:50
There is a collar on the rear piece behind the spring. Under the collar is a pin the holds the two pieces together. Then the shaft will slide ahead enough to let the ratchet out. Then I don't know or remember if there is enough room for the shaft to go out the back. I've never taken one apart with the bolster still on the tractor.
RustyFarmall
01-09-2008 04:34:07
You will have to completely remove the front end from the tractor in order to get that assembly out.
