Re: Farmall A front pivot pin
Hendrik
01-09-2008 02:23:48
Andrew Z is correct; you need to remove both bolts fully. Even then I had a hard time HAMMERING the pin out. It seemed pretty loose but still took quite some effort to remove and the pin didn't even have wear grooves or nicks...
