450 HYD.
Hoss357
01-10-2008 04:22:24
what would make the hyd build pressure..i went home squirted some hyd oil in the plug of the pump..started tractor work levers a little...walked away and let it run a couple min. i came back oil coming out of the top of resv.... a line wasn't tight and so on..tightened line oil stopped coming out..p/s and loader started working a little thought maybe something gave and it was low on oil...pulled the dip stick and got a shower of oil..let it sit a while and started over didn't do it again but loader and p/s havn't started working again either????
Janicholson
01-10-2008 07:33:06
 Re: 450 HYD. in reply to Hoss357, 01-10-2008 04:22:24
If there was any H2O in the system, and if it is below freezing, the return (supply side screen could have been blocked. Pressure could have then built in the res. (just a guess) JimN
