H fan blade removal
IH H owner
01-10-2008 15:57:27
Yes this is probably a silly question BUT, Ive never had the fan off of a H before. I was adjusting the fan belt and broke the cast ring thats the front half of the pulley on the water pump.Do I have to take the small bolt out on the springs on the long bolts? I have the small nut off the bolt but it wont move. What is the easiest way to change the adjusting ring? do I have to remove the radiator? Where can I get another ring? Still available from Case IH?? Thanks Doug
riverbend
01-10-2008 16:48:06
 Re: H fan blade removal in reply to IH H owner, 01-10-2008 15:57:27
Bad news. You have to take the water pump apart to get the moveable flange off. It is not difficult, but it is a bit of a chore. I ran mine for several years with a cracked sheave.
Greg
KRUSS1
01-11-2008 06:38:28
 Re: H fan blade removal in reply to trulyred, 01-10-2008 16:44:02
After much deliberation, I found it easier to remove the radiator, then the water pump. Getting that pin out can be difficult. There a lot of IH tractors that fell into the category of "running when parked" over that pulley shieve.
