H oil canister
Arf
01-11-2008 02:50:57
I was told the top of my oil filter canister leaks on my H because it has been over-tightened. Is there anything I can do to remedy this?
Arf
01-11-2008 05:25:32
 Re: H oil canister in reply to Arf, 01-11-2008 02:50:57
It is the tall one. How much?
Nebraska Cowman
01-11-2008 05:23:58
The top should be smoothly domed. If it has been smashed down, caved in you will need to get a replacement. I have them but will need to know if it is the short or tall filter.
IaGary
01-11-2008 05:09:31
Have you tried a new washer?
You can also heat up the old copper washer with a torch and it will soften it up again.
It will seal better when it is soft.
Gary
