Super M engine serial # question
CityBoy-McCoy
01-11-2008 06:53:40
Howdy, boys. Is there some correlation between chassis serial numbers and engine serial numbers with regard to Super M's? My chassis is in the 42,000 serial number range, and my engine serial number is in the 100,000 serial number range. Yet, the engine casting dates are compatible with the rest of the tractor. Thanks in advance for any help. mike durhan
D Slater
01-11-2008 10:17:30
 Re: Super M engine serial # question in reply to CityBoy-McCoy, 01-11-2008 06:53:40
Your below the # SMTA C-264 engines started at, so its a regular SM engine. Same engine numbers were used for Louisville and Farmall and I think SW6 also,so they can have quite a spread sometimes.
Guy Fay
01-11-2008 09:57:23
They did not match on the Super M.
RustyFarmall
01-11-2008 08:53:10
There has been some discussion on this before, and I don't remember what the exact conclusion was, but it seems that the Hs and Ms up to a certain year most likely DID have engine serial numbers that matched the chassis numbers, but after that point it is quite likely that the numbers would NOT match. If the casting codes are in general agreement, I would guess the engine is the original.
