high heat paint
Andy in Indiana
01-11-2008 08:29:02
does the block of an H need high heat paint, i used high heat Primer but have not looked for IH Red high heat paint yet, also, I have a factory hole on the exhaust side of the block half way up, I do not see any threads, what is it for? it is about 1/2" to 3/4: in diameter and I do not remember what was there before I had the block "tanked" thanks
RustyFarmall
01-11-2008 08:43:21
 Re: high heat paint in reply to Andy in Indiana, 01-11-2008 08:29:02
You do not need the high heat paint.
The only hole I can think of is the block drain plug hole. It should be threaded for a NPT pipe plug.
Andy in Indiana
01-11-2008 09:27:11
 Re: high heat paint in reply to RustyFarmall, 01-11-2008 08:43:21
Thanks, I didn"t think I needed high heat paint, and I"ll look tonight and see if there should have been NPT threads there, if not, I"ll retap them... but I believe you"re right on.
