ih 350u
greg t lang
01-11-2008 11:34:41
i have a ih u350 front loader seems weak wont lift much unless its at high throttle and it gets
progressively worse as you continue to use it
anyone have any ideas where to start on this also very slow thanx greg
Janicholson
01-11-2008 11:59:23
 Re: ih 350u in reply to greg t lang, 01-11-2008 11:34:41
Georgeky is right. If the Fast hitch is accessible, and you have an implement like a disk, or plow, and it lifts them with good speed even at idle, I would look at other components, like a collapsed screen under the seat, or a partially non centered valve. If none is available to assist in the diagnosis, it is likely the pump. Small cylinders on the loader can have that effect, but if the loader has been on it for a long time, or is designed for the pressure, it needs a pump. They cannot be helped much with a rebuild. JimN
georgeky
01-11-2008 11:50:14
Sounds like you need a new pump. Need to have that one tested with a flow rater.
