IH and/or Case Yellow Paint
bc
01-11-2008 13:06:08
Hi, I have the backhoe/loader i now believe to be an IH 2656. The tractor and loader is painted a medium brightness flat yellow and may not be an original color and the case backhoe has a darker flat yellow which is the original Case color but not as dark as Cat yellow. The engine looks to be an IH Red.
I can"t match it with any implement paint at the farm supply. It isn"t a bright as New Holland Yellow and there don"t seem to be any darker alternatives. Someone may have painted it some type of equipment or safety yellow but everything at the store seems too bright and glossy.
Is there a particular IH or Case yellow which I should use and where can I find it?
gmd
01-12-2008 11:59:56
 Re: IH and/or Case Yellow Paint in reply to bc, 01-11-2008 13:06:08
Having painted a few newer case backhoes, and a 2544, the closest thing you can find will be from the dealerships. That industrial paint is something that hardly no one ever uses. One thing you can do is if you have an auction company nearby that does a lot of equipment sales, often times they have the paint made themselves for repainting so much equipment before the sales. The last Hoe we did we bought it from them for less. They made money on the paint and we saved money, so everyone was happy.
Harold H
01-12-2008 06:18:43
I believe that IHC industrial equipment in the 60's and 70's was painted "Federal Yellow".
Harold H
James Early
01-13-2008 12:13:53
 Re: IH and/or Case Yellow Paint in reply to Harold H, 01-12-2008 06:18:43
Also called "School Bus Yellow"
RustyFarmall
01-12-2008 06:18:18
Have you looked at construction yellow?
Nebraska Cowman
01-12-2008 04:37:27
New Holland has 2 or 3 differnt yellows.
glennster
01-11-2008 13:17:28
see if you have an ici dulux paint store or a sherwin williams paint store near you. look at the alkyd industrial enamels, mainly , saftey yellow. more than likeley the tractor has been repainted a saftey color. they can also tint up and down to get a close match with the industrial colors.
