MW 9-speed in Farmall M
Armand Tatro
01-12-2008 15:54:54
Is it possible for the M&W 9-speed to lock in two gears the same as the shifting forks in the main trans? This 9-speed has shaft through case; not cable shift. Also where can I find a book on the 9-speed and also a book for the M&W IPTO? Also would the 9-speed manual cover both the cable-control and the shaft linkage 9-speeds. Thankyou for any help. Armand
r4etired
01-12-2008 18:37:41
 Re: MW 9-speed in Farmall M in reply to Armand Tatro, 01-12-2008 15:54:54
The way a 9spd shifts it is impossible for it to be in both ranges,The sliding gear is not wide enough when in nuetral to reach both ranges.
gene bender
01-12-2008 17:08:19
Just type in M@W in search and it will come up their tele is 217-784-4261
