300U Hydraulic question
AJ Clark
01-12-2008 17:35:17
My hydraulic oil for my loader is contaminated with water. I have new oil to replace it with but I would like to put a spin on filter in the return line. Which of the 2 lines coming back from the pump is the return??? top or bottom?? Has anyone ever done this before??? Anyone have any advice or comments??
Janicholson
01-12-2008 23:36:18
 Re: 300U Hydraulic question in reply to AJ Clark, 01-12-2008 17:35:17
The big line is the suction, the little pressure.
There needs to be substantial flow rate (maybe 5 times the pump volume) to assure low (or no)restriction in the suction line. Getting the air out is a hassle, as is making it look neat. I don't think there is much advantage in the filter. Heating the oil (some have used a turkey fryer outside the home) to drive out the moisture. Volatile oil is a hazzard when heated, be careful and attentive. JimN
