F-20 gas tank srap material
Scott Rukke
01-12-2008 20:16:35
Anyone know what the material is between the tank and hold down strap and where it's available? Thanks
Pete in Holland, MI
01-15-2008 14:45:53
 Re: F-20 gas tank srap material in reply to Scott Rukke, 01-12-2008 20:16:35
I use the red webing from a cheap ratchet tie down. Same color as the tractor too !
Farmallgray
01-14-2008 17:49:10
 Re: F-20 gas tank srap material in reply to old, 01-12-2008 20:16:35
Scott Rukke said: (quoted from post at 21:16:35 01/12/08) Anyone know what the material is between the tank and hold down strap and where it's available? Thanks
If you can find the wick material for the old coal oil lanterns, I believe it is about the same thing.
karl f
01-14-2008 16:09:28
we used an old cow collar one time on a machine that had to get back in the field. it's too thick to fit proper though
karl f
Bob Kerr
01-13-2008 07:45:53
It is a cotton webbing. Some old cars use something simillar on the old 20s style folding hoods but is saturated with a kind of wax. Not sure if IH ever used the waxed stuff, but they were put on and then painted over when it was all assembled. As said below, rice has the closest stuff you will be able to find. Be sure to pad the bottom of the tank also.
Bob Kerr
01-13-2008 07:45:28
STEWARTINPA
01-12-2008 23:56:09
Scott Rice Equipment has that he sells it by the foot Gordon's number is 814-226-9200 I hope this helps Stewart
