Help identifying a tractor engine
TX-Help
01-13-2008 10:18:11
third party image
third party image
I recently acquired a tractor engine from a friend and need help identifying what I have. Most of the front end of a tractor was mounted on a trailer and converted to a stationary engine to run an air compressor. It is a 6 cylinder LP engine with IH markings on it. I can"t find any serial number on the engine or clutch housing. The hood has been painted several times, but some investigation shows it was originally yellow with red lettering "MCCORMICK" about 3.5" tall and 33" long. I don"t see any other decals on the hood. Any help will be appreciated.
TX-Help
01-22-2008 19:15:34
 Re: Help identifying a tractor engine in reply to TX-Help, 01-13-2008 10:18:11
I found a stamping on the engine that says
HT141
9210
Would this be a Harvester Thresher 141 engine? Does anybody know anything about this engine? It does look a lot like the SD220.
TX-Help
01-14-2008 18:23:10
Thanks a lot for your help. I think you are exactly right. I found some pictures of a SD220 online and it looks almost identical to my engine. I guess I saw IH on the engine and the hood with McCORMICK on it and assumed right away it was out of a tractor.
thanks again!!
CNKS
01-13-2008 12:53:57
I missed the downdraft carb, but the C221,etc is a derivative or the 220 truck engine, I believe.
Allan In NE
01-13-2008 12:46:05
"Looks like" a 220 or 258 IH truck engine.
Allan
Steven f/AZ
01-13-2008 12:05:07
Looks kinda like the Silver Diamond 220 engine in my 51 IH L-120 pickup:
third party image
JLE
01-13-2008 11:52:46
Having a down draft carb, I believe it is a truck engine. May have been an early stand by power unit. May be even on some older combines.
CNKS
01-13-2008 10:47:29
Appears to be a version of the C221,263,291,301 engine used in the 460/560/706/806 and others.
