Compression question
rick in sc
01-13-2008 17:05:09
When using a 251172R (C/SC? gas)head on an "A" with 3 1/8" bore and the domed pistons, what approximate compression ratio should I end up with?? I haven"t ordered pistons yet and didn"t want to end up with a detonation or overheating problem as this tractor will be used for gardening, but really would like all the extra power I can get. Thanks ahead of time!!!
El Toro
01-13-2008 18:08:40
 Re: Compression question in reply to rick in sc, 01-13-2008 17:05:09
I restored an A 32 years ago and I used the 3.125" flat top pistons from our local IH dealer and when I got it running I plowed the garden with the 16-inch plow and it would have some wheel slippage when plowing sod and was never short on power. You have enough power if it can cause wheel slippage. I had wheel weights, but no fluid in the tires.
You need to clean that block area thoroughly where the seals are installed as Gene suggested of all rust & dirt. Coat the lips of new sleeves with dish detergent and clean that recessed area at the top of the block too. They do a nice job plowing. Hal
gene bender
01-13-2008 17:28:48
If you arent changing the sleeves i would take the radiator off and then the lower housing on the block and back flush that area as the holes where the coolant goes down by the sleeves could be plugged.Clean that area out as ist probably got lots of junk in there using a good lite you can see if you got the junk out. I just tore down three blocks and the rust and crud in that area was bad.
rick in sc
01-13-2008 18:41:05
 Re: Compression question in reply to gene bender, 01-13-2008 17:28:48
This tractor is getting another block as the original had a bad run in at some time in the past with one of the laws of science; water expands at 32`F and lower temps. Cracked so badly the head was cracked from cyl.#1 to cyl.#4. Everything has been hot-tanked. I saw a set of 3 1/8" pistons & sleeves that have a very tall dome (high altitude fire-crater maybe??) and thought they would be the trick for a lot more power; something this tractor has never had being a fuel burner. Actually kinda hard to cultivate with since it had no power at low rpms and a bit too fast with the rpms up. (At least for me)
