Stage1 or Stage2 ?
TX. Bulldog
01-13-2008 18:18:34
I have a 1953 Super H. It needs A new starter, and the catalog I have been looking at lists a stage1 and a stage2. How do I determen which one I need ?
gene bender
01-14-2008 05:59:04
 Re: Stage1 or Stage2 ? in reply to TX. Bulldog, 01-13-2008 18:18:34
Check the bolt pattern on the starter as thats the one you need also the DELCO REMY # will also tell you.
pat in wis
01-13-2008 20:04:09
whats the serial number? if its after 19234J then its a stage 2
would still like to know the number,
Pat
Andrew Z
01-13-2008 19:09:11
Look at the front bolster casting if its a true stage II it will have cast holes in them, like the SMTA, 300, 400 etc... other areas to look at are if the bell housing has a cast indent on the left side. that would have been a place for the hydro line to rest. there shold be no signs of a belly pump, no holes for the out lets for the pump if its a stage II
Andrew
D Slater
01-13-2008 18:56:48
If the starter uses 3 bolts to mount it and is located on left side of tractor center line its a stage 2. If starter uses 2 bolts to mount and is located to right of tractor center line its a stage 1.
CNKS
01-13-2008 18:33:34
Remember that the Stage 2 seat will fit on Stage 1. A true Stage 2 will have a live hydraulic pump in front of the distributer and a hydraulic reservoir under the gas tank.
TX. Bulldog
01-13-2008 18:41:25
 Re: Stage1 or Stage2 ? in reply to CNKS, 01-13-2008 18:33:34
Mine has the pump in front of the distributer and the reservoir under the tank but I still dont see the difference.
CityBoy-McCoy
01-13-2008 19:39:25
 Re: Stage1 or Stage2 ? in reply to TX. Bulldog, 01-13-2008 18:41:25
Relax. Then, re-read what D Slater said. Count the number of bolts holding your starter to your tractor. As D Slater stated: 2 bolts = stage 1; 3 bolts = stage 2.
mike
NE NEB FARMALL
01-13-2008 18:27:16
If the battery in under the seat then it is a stage 2. Stage one has battery under the fuel tank
