656 PTO Question
skyharborcowboy
01-13-2008 21:44:44
How can I determine if I have a 540 RPM or 1000 RPM PTO? I was looking up the part number for the Hydraulic filter and it shows two part numbers one for th3 540 and the other for the 1000.
Thanks,
Joe
PS. How hard should the pull on the lever be to engage the PTO?
skyharborcowboy
01-14-2008 10:40:40
 Re: 656 PTO Question in reply to skyharborcowboy, 01-13-2008 21:44:44
Key Qty Part Number Part Name Description 1 ATTACHMENT, independent PTO, 540 RPM, 389119R92, Farmall tractors, 395874R91, International tractors, consist of all unmarked parts & those marked unit A, for independent power take-off lever and connections refer to section H 1 Service parts for 1000 RPM independent PTO w/hand operated controls, consists of all unmarked parts & those marked unit B 1 Service parts for 1000 RPM independent PTO w/foot pedal controls, consists of all unmarked parts & those marked unit C 1 1 389141R11 SHAFT SHAFT ASSY, PTO extension
skyharborcowboy
01-14-2008 10:34:48
It is in the service manual I have as well as the parts book.
Joe
Steven f/AZ
01-14-2008 10:16:52
656 was available with 1000 rpm PTO? Can anyone verify this?
I may have just learned something today :shock:
georgeky
01-14-2008 11:03:35
 Re: 656 PTO Question in reply to Steven f/AZ, 01-14-2008 10:16:52
Yes they were available with 1000 RPM PTO. Had to have a seperate unit installed for it.
skyharborcowboy
01-14-2008 07:33:05
It also appears that my PTO lever is seized in the shaft housing that runs from the handle over to the left side of the tractor. I will need to put some penetrating oil in there to break it loose.
Joe
Allan In NE
01-14-2008 08:44:32
 Re: 656 PTO Question in reply to skyharborcowboy, 01-14-2008 07:33:05
Soak it and go gently so that you don't ruin those roll pins.
Probably hasn't been used much. A good thing, really. :>)
Allan
skyharborcowboy
01-14-2008 07:30:25
If I end up needing a pump that is what I will do. I just wasnt sure which pump is in there now for the Hydraulic Filter change.
Joe
Armand Tatro
01-14-2008 04:50:07
Check your owners manual or I&Tmanual for SN codes. There was a letter in the 560 SN that indicated whether the hyd. pump was 12GPM or 17GPM. Armand
skyharborcowboy
01-13-2008 21:58:42
Thanks,
I just found another wrinkle to the deal. How do I determine if I have the 12GPM Pump or the 17GPM pump? I figured that CaseIH would have it broken down by serial number. Do the 17GPM pumps interchange with with the 12GPM? My tractor is a 1967 model.
Joe
Allan In NE
01-14-2008 05:05:40
 Re: 656 PTO Question in reply to skyharborcowboy, 01-13-2008 21:58:42
Don't even think about it. Put in the 17gpm pump.
Difference is like night and day if you ever end up using the tractor for loader work.
Allan
georgeky
01-13-2008 22:28:37
Either pump will work in your tractor. Tractors after serial No 13012 had the 17 GPM pump. The pto lever should work smooth and easy.
Bob
01-13-2008 21:53:50
540 PTO has 6 splines, 1000 RPM PTO has 21 splines.
skyharborcowboy
01-13-2008 21:47:56
Item 21
https://webparts.pvassociates.net/cnh/printfigure.php?FigureID=35054&ModelID=205
