Holy Cow - Rear right-angle belt pulley
Wardner
01-14-2008 03:26:16
That belt pulley on eBay went for $760 plus $75 shipping. I laughed when I saw the seller's opening bid of $500.
I think I will have to sell mine. It is new old stock.
I suppose it is a rare item.
Last summer, I offered a pintle hitch from my I-9. It fits all series 4, 6, and 9 standards plus 04-06 standards and maybe more. I know it is rare. Just ask Howard H. I saved all the big dot-heads, sandblasted, and painted it. No one was willing to hit my reserve of $300.
karl f
01-14-2008 15:56:00
 Re: Holy Cow - Rear right-angle belt pulley in reply to Wardner, 01-14-2008 03:26:16
keep in mind it was for 1000rpm pto. the internal gearset and spline coupler would have been unique for 1000 rpm shaft. while the pulley and gearbox aren't so rare, it's the internals. for those not familiar: 1000 rpm pto not only spins faster, but has a different spline count--21, there's also a larger 1000rpm shaft out there too with only 20 splines.
my 2 cents
karl f
Wardner
01-14-2008 16:41:06
 Re: Holy Cow - Rear right-angle belt pulley in reply to karl f, 01-14-2008 15:56:00
Karl, what you say is true.
I don't have have a parts book that list the 1000 rpm units so I can't compare the internals with the 540 units. I do know the 540 gear boxes are offered in several ratios.
However, the ratios are fairly close to 1-to-1. A little plus and a little minus. The ratios are probably similar to the Cub and A/C right angle boxes.
The gearbox offered on eBay may be the same as the 540 box but fitted with a 540/1000 adaptor. The adaptor wouldn't require more than 3/4" additional space which could be made up with a spacer between the tractor and gearbox.
I don't know if these assumptions are correct. I am just guessing. If they were the same, it would be cheaper to inventory only one box and the conversion parts.
ny bill
01-14-2008 08:02:38
guess i should dig out the unit i have that went on the back of dad's jd 1010 crawler. i'd be glad to get the opening bid's worth out of it.
pics
01-14-2008 09:44:34
 Re: Holy Cow - Rear right-angle belt pulley in reply to ny bill, 01-14-2008 08:02:38
Ya, that's a good idea. I have one that fits a TD-14 but it is nowhere near as beefy as the tractor models.
Andy Martin
01-14-2008 05:45:46
We'll all be rich!
RustyFarmall
01-14-2008 04:38:38
Ebay is a great place to buy and sell, but I have a hard time believing some of those prices.
Things are not always as they seem.
Do you still have that pintle hitch?
Wardner
01-14-2008 09:12:28
 Re: Holy Cow - Rear right-angle belt pulley in reply to RustyFarmall, 01-14-2008 04:38:38
third party image
third party image
third party image
I have the bars too. They only fit 9 series and probably 560/660 standards. All four mounting bars are easily fabricated for the other sizes. I know the dimensions for the 4 series. I think I can calculate the 6 series bars.
Took me 5-6 hours to remove the hitch. I had to use my 50-to-1 torque multiplier.
James Williams
01-14-2008 14:13:18
 Re: Holy Cow - Rear right-angle belt pulley in reply to Wardner, 01-14-2008 09:12:28
Wardner,I havent heard anyone metion a multiplier in years,there probally scarace as hens teeth
jimmy
