IH 234 Mounted Picker
TV Iron
01-14-2008 14:19:27
Is the weight of a 234 IH picker too heavy for a Super M tractor? I am concerned about the rear axle bearings.
gene bender
01-14-2008 16:23:19
 Re: IH 234 Mounted Picker in reply to TV Iron, 01-14-2008 14:19:27
The SM will carry it just be careful. Your big problem is if the corn yeilds over 150bu and is planted too thick you will run out of power.
Steven f/AZ
01-14-2008 16:21:37
Don't drive in road gear over rough terrain!
chuck46
01-14-2008 16:05:29
TV, I have used a 234 on an MD or a 450D for many years without a problem. Good luck, Chuck
randy hall
01-14-2008 15:48:17
the 234 is heavier than a new idea. i have seen several mounted on m's .
georgeky
01-14-2008 15:45:06
Don't know, but I picked a million acres with a New Idea on an M. Never had any problems with it. Never had a 234, but would sure like to. Friend of mine has one, and it will pick circles around any I ever seen.
Armand Tatro
01-14-2008 15:27:20
We had a 2MHD mounted on a farmall 400 and broke an axel. A neighbor had a 2MHD mounted on a case 400D. and broke an axel. I know of a 234 mounted on a M Farmall. Not sure if he broke any rear axels or not. Armand
IaGary
01-14-2008 15:14:00
We broke the axle on a 450 with a 234 hanging on it.
Gary
