42 wheels for Farmall 544
Trent544
01-14-2008 15:50:10
Are the 42" rims and centers hard to find for a 544? I would like to find a set to make good spraying tractor even better. What other tractors would have the same optional 42" wheels, 656? 460-560?
K.B.-826
01-14-2008 18:58:41
 Re: 42 wheels for Farmall 544 in reply to Trent544, 01-14-2008 15:50:10
Maybe you could find a pair of 42" pressed-steel wheels to fit the nine-bolt hubs that were avalible for the 544. The hubs are fairly easy to find. 656 hubs will fit. 460/560 wheel equipment will not fit due to the different axle keyways.
Trent544
01-15-2008 15:57:09
 Re: 42 wheels for Farmall 544 in reply to K.B.-826, 01-14-2008 18:58:41
The pressed steel wheels would be a good idea, they would be lighter weight too, less compaction when carrying 200 gallons of water on the back.
w gatewood
01-14-2008 18:11:05
u can use step up wheels and stay with your centers call your local tire dealer, underferth is the mfg of the rims you need
Trent544
01-14-2008 18:34:48
 Re: 42 wheels for Farmall 544 in reply to w gatewood, 01-14-2008 18:11:05
I thought about that, but those rims are fairly expensive. May do it sometime if I can't find some original type wheels off a salvage tractor.
