460 waterpump to long?
Gary in Mozarks
01-14-2008 17:13:59
I went to replace the fanbelt on our 460 gas utility today and noticed that the water pump pulley is about 1 1/2 inches farther forward than the crank pulley or the gen pulley. The water pump pulley is flat. Has anyone ever run across something like this before? Either it has the wrong water pump or the wrong pulley? If the pulley was dished to the rear it would line up. Thanks Gary
mkirsch
01-15-2008 07:13:00
 Re: 460 waterpump to long? in reply to Anthony Jones, 01-14-2008 17:13:59
Necessity is the mother of compromise... The original pulley probably broke, and the right part was either unavailable or too expensive.
Gary in Mozarks
01-14-2008 20:31:28
 Re: 460 waterpump to long? in reply to wildman from mo, 01-14-2008 17:13:59
I think you are right on the money, Not sure why someone would put the wrong pulley on it but thats what it appears to be. It;s flat. I looked up the diagram on www.caseih.com and it appears to be belled as you suggest. Now to find someone that has the correct one for sale.
Jerry Gilliam
01-16-2008 16:32:46
 Re: 460 waterpump to long? in reply to Gary in Mozarks, 01-14-2008 20:31:28
Thanks for posting about the Case/IH site. I have a 460, 656, 244 and it has been a help in located some info I needed. thanks again
Jerry
Kevin Meier
01-15-2008 14:26:10
Make sure you get the bolt on pulley if your water pump has a hub on it. There is also a pressed on version of that pulley too.
Kevin Meier
01-14-2008 18:07:08
 Re: 460 waterpump to long? in reply to Gary in Mozarks, 01-14-2008 17:13:59
I am assuming that you have a bolt on pulley? If so the pulley shouldn't be flat. It is probably around 3 to 4 inches tall and bolts to the hub and comes fairly close to the water pump casting surface at the top.
