1206 Injector Lines
Dubl J
01-15-2008 07:23:23
We are at the stage in our DT-361 re-build to start to put on auxiliary items. While inspecting the injector lines I noticed that some of the holes are much larger than others. It does not look normal, and appears as if they are either larger from wear or from being installed incorrectly. Are there new lines available from anyone or can these lines be used again. Before the engine was re-built there was a lot of leaking accruing around where the lines meet up with the pump. This tractor will be re-painted once the engine and other parts are re-assembled, and most of the leaks are fixed.
Thanks
Jeff
Larry806
01-15-2008 08:26:16
 Re: 1206 Injector Lines in reply to Dubl J, 01-15-2008 07:23:23
Went through that on my son's . You can price new but than look for good used . Remember that the 1206 has different lines than a 806
Wisconsin Cowman
01-15-2008 07:40:01
I would put new lines on. You can get them through Case IH.
