Order Farmall Cub Parts Online
Shorty muffler ideas for a Cub
mkirsch
01-15-2008 11:17:30
In the process of reconstructing a TwinDraulic loader frame on my Cub, I've discovered that the 3" square tube I used to mount the loader to the final drives interferes with the underslung muffler. The exhaust pipe can't be angled enough to get the muffler around the loader frame.
Until I get the frame mocked up, I don't want to take it off the tractor, but I still need to move it around and use it occasionally. I'm in a semi-rural residential neighborhood, but the tractor is simply too loud without a muffler.
I've got the exhaust pipe installed, but that doesn't help much. A muffler that's 12" or less in length would work. Does anybody know of anything that might fit that description? The exhaust pipe is 1-1/4" outside diameter and about 1-1/8" inside.
Janicholson
01-15-2008 13:15:52
 Re: Shorty muffler ideas for a Cub in reply to mkirsch, 01-15-2008 11:17:30
If you purchase a 2' section of stainless steel flex tubing the correct inside diameter, it will allow the existing muffler to bypass the frame. JimN
RN
01-15-2008 13:11:31
Maybe check out the Harley dealer for a shorty muffler with baffle? Ask about used pieces from back shelf, $5.00 got me a shorty that fits a 12hp Tecumseh in a Simplicity, quiet the cub down for awhile, cheap. RN
gene bender
01-15-2008 12:19:42
Could you go to a muffler shop and have them bend you a 90 so the muffler down paralell to the hood or even bend a u-shaped and hang the muffler down. I do this so the muffler hangs down and not hit the tree limbs.
Steven f/AZ
01-15-2008 12:01:04
Look up "Hushpower" mufflers on Summitracing dot com
Link
No personal experience with them, but have read many good reviews on them being a compact and reasonably quiet muffler...
If you don't want to go that route, they do make glass packs that are 12" long and not too big around, too.
dave guest
01-16-2008 17:16:55
 Re: Shorty muffler ideas for a Cub in reply to Steven f/AZ, 01-15-2008 12:01:04
How you gonna know its running? I love that sound. I never had muffler on cub or A. Ford 4000 Yes little more decibels.
david b. guest
01-16-2008 17:15:49
