Farmall M wiring help
firsttimefarmall'er
01-15-2008 17:22:05
Hey got a problem. Just recently purchased a '52 Farmall M that is not running. The purchase came wit h a new wiring harness (for OEM i believe). The problem is i dont know which wire goes where. I have printed "Bob's diagram," But need to know which wire from the harness goes where. Any help would be much appreciated.
~T
Jossette
01-16-2008 17:09:15
 Re: Farmall M wiring help in reply to firsttimefarmall'er, 01-15-2008 17:22:05
third party image
gh
1 Dollar
01-16-2008 19:48:18
 Re: Farmall M wiring help in reply to Jossette, 01-16-2008 17:09:15
Hey, that's a good one. I can use this on my above post. Don't wanna hijack this one.
ScottyHOMEy
01-15-2008 18:19:03
A couple of thoughts.
I bought an old-style cloth-loom harness from an outfit that went so far as to use the original colors for the individual wires, so I could follow the diagram in my owner's manual. And in case I didn't have an owner's manual, they labeled each end of each wire with a number, and provided a chart of where each went.
If yours did come from OEM, I don't know if theirs stick with the original colors or not, but I should expect they could come up with a wiring diagram for you.
If not, look your harness over and trace down each end of each wire (red, black, white with red tracer, white with black tracer, etc.) and compare how the harness matches up with the diagram in the owner's manual. For the harness that runs out of the ammeter box, it would be mostly a matter of finding the way things reach and fit best on the front end, and then making sure the back end of each wire gets hooked up right.
The manuals for my SuperC and my BN both had the diagrams, and it's bretty easy to distinguish where there's a harness vs. an individual wire.
CNKS
01-15-2008 18:14:30
You can use the wiring diagram in the M Operator's manual. Although the color codes may be different, you should be able to figure it out, provided that the new harness has close to the same dimensions as the original.
firsttimefarmall'er
01-15-2008 17:42:09
I sent them an email but havent heard back yet. I know I can count on this forum for some asnwer! I have a page with number for some of the wires but it is very breif only saying "main harness" not which wire goes were
CityBoy-McCoy
01-15-2008 17:32:12
As a suggestion, why don't you contact OEM and see if they will help you? Maybe they will send you a diagram with color codes or something similar. mike durhan
