1466 6 Volt Charging
61-4010
01-16-2008 11:38:06
Hey all. Have 2 6 volt batteries out of my 1466 and unfortunately 6v charger is out. If I connect these batteries in series (positive to negative) hence giving me 12 volts, can I charge them together with a 12v charger under a trickle charge?
randy hall
01-16-2008 20:43:12
 Re: 1466 6 Volt Charging in reply to 61-4010, 01-16-2008 11:38:06
how do you think the alternator on the tractor charges twelve volts into those batteries? hook the negative to the frame and the positive to the terminal closest to the starter.that would be the front of the left battery.
JT
01-16-2008 12:03:04
If you hook them in series to get 12 volts, you do not need to trickle charge them, charge them like you would any other 12 volt battery.
Jim
mkirsch
01-16-2008 11:54:50
 Re: 1466 6 Volt Charging in reply to bbelltn, 01-16-2008 11:38:06
They are supposed to be connected in series on the tractor too. If you've got them in parallel, that would explain why you think they're dead.
Bill in IL
01-16-2008 11:47:41
Yes as long as they are both good batteries. You could check them with a hydrometer if you doubt them.
