what should I pay for a M parts tractor
az tractor guy
01-16-2008 13:07:48
Hi,
I was just wondering if $100 is too much for a parts tractor? In this case I would only be getting the back half of the tractor plus the clutch housing.
Thanks!
edward_m
01-16-2008 19:53:51
 Re: what should I pay for a M parts tractor in reply to az tractor guy, 01-16-2008 13:07:48
scrap is going for 140$ a ton in southeast IA....if its anywhere close to that where you are, you can't loose money even if you don't part it out.
Heck, even if you part it out, you'll still make a profit on the chassis in steel alone!
Mike 50
01-16-2008 15:55:38
That price aint bad, its worth more than that as scrap.
Zach Bouchard
01-16-2008 14:17:15
It is worth its weight in scrap. 100 bucks is a good deal.
georgeky
01-16-2008 13:39:41
Like Rusty said, If it has the gears, axles, shafts and all it is a bargain. Just one of those parts used will cost more than that.
RustyFarmall
01-16-2008 13:11:08
Are all of the gears still inside the trans/differential case? If so, $100 would be a steal.
az tractor guy
01-16-2008 13:25:39
 Re: what should I pay for a M parts tractor in reply to RustyFarmall, 01-16-2008 13:11:08
It is all there.
RustyFarmall
01-16-2008 17:25:10
 Re: what should I pay for a M parts tractor in reply to az tractor guy, 01-16-2008 13:25:39
Buy it, don't hesitate.
